gauges in 07' ????
gauges in 07' ????
I'm planning on putting the Automters from my 01' into the 07' when it gets here, I was wondering where the best place to get a full replacement pillar was?? are the 03'-05' pillars the same as the 06'-07''s????? also do you think I'll get any crap from the dealer for gauges alone???? not planning on any boxes or programmers, & the exhaust will stay stock for sure, should I have any problems with just adding gauges to keep an eye on things????? if it's gonna be more trouble than it's worth than I may not even bother with them???? thanks, Dusty
i know the 03-06 pillars are the same, not to sure about the 07's though. check this website out for the pillars. http://www.dieselmanor.com/pillars_p...ts_pillars.asp
the pillar shown in the pic is black, but the pillars for the dodges match the stock pillars perfect.
I have not been bothered by my dealer because of them.
put'em on if they say "you have a Chip"... you say... "prove it"
if your worried call the dealer and ask them or just ask them next time you take it in for something.
That was a test run to see if I like the gauges mounted there and to see if they were in the way of the other gauges. I wasn't sure if that mount was going to work on a 07. It's not permanently mounted there yet. One is the rail pressure and the other in air pressure. I have a 5 gal air tank for train horns I have to install and a future exhaust brake.
I do plan on leaving them there as soon as I can get time to make the install permanent.
Kman9090
29
12-06-2007 06:43 PM
coontz0473
17
09-22-2006 03:52 PM
estesbubba
07-18-2006 04:35 PM
AggiePhil
01-30-2005 01:15 PM
