gauge taps
gauge taps
where has everybody been tapping a hole for the pyro, boost, and fuel pressure gauges? I am going to be adding a set to my truck in the next few days. Thanks.
Ross
Ross
I am using the outlook from Bully dog. It plugs into the existing port on the truck for all of the temperatures and pressures except the exhaust. I drilled from under the truck into the elbow after the turbo.
buy a boost bolt for the boost gauge
buy a tapped banjo for the FP
check my gallery for pyro mount location..
search the forum there is a ton of ways to mount the pyro, I unbolted my turbo to drill and tap but there are other ways...
of course you should call Lary in the DTR store and see if they have these before you buy from somewhere else....gotta support the site
http://www.dieselmanor.com/dm_products/DM-DBBLT.asp
http://www.dieselmanor.com/dm_products/DM-BSTBLT.asp
