Gauge Install - I killed by Panel Lights!
Gauge Install - I killed my Panel Lights!
Here is a weird one...
I installed the ISSPRO 3 gauge (pyro, trans, boost) from DieselManor this weekend and somehow I did something to the wiring. I connected to the orange-brown wire coming off of the light switch to supply power to the lights on the new gauges. Well, the new gauges don't light up and now I can't control the illumination of my instrument panel gauges. The instrument panel gauges and radio display dim when I turn on the headlights, but I can't control the brightness and when I turn the brightness switch all the up, the interior lights don't come one.
Any ideas? I checked any of the fuses that I could find and everything is fine there. Did I short something out? Is this illumination controlled by the body computer? Is this something that the dealer will need to scan to correct?
Any help appreciated...
Thanks.
Seth
Thanks.
Seth
I agree, use a test light to see what lights dim with the factory dash lights. I used the cigarette lighter for power, but I cant remember what wire I tapped for lighting, sorry.
Could be a orange wire with brown or black stripe.
Mine was orange/brown tracer.
Looking from the back of the guage, bottom right wire.
Get out a test light and test it with the lights on, should get dim/brighten with the dimmer switch. If you dont have a test light, go get one, very handy.
From diesel manors site...
Like they said, '06 might be different colors, but should still be orange, might be orange/black
Why are you messing around tapping into wires. All you need is an add-a-circuit which adds a fused circuit to your fuse panel. Plug the add-a circuit into the dash light fuse and you the new wire to power your gauge lights. The dash light dimmer feature will also dim your guages.
http://www.partsexpress.com/pe/showd...number=071-580
There's nothing wrong with tapping the wire, just sounds like you have wrong one.
I used the 12V ignition that is supposed to be for power pedals (which I don't have) It appears to be the same one everyone is pointing to up top there. Take a deep breath, this is not a reason to take the truck to the dealer.
RyeThomas
07-11-2007 05:31 PM
13ALPHA
05-23-2007 02:54 PM
CUMMINSBILL
06-06-2003 11:02 AM
