gauge instal
gauge instal
where do you run all those wires through.found 2 nuts that hold a plate on but that leaves me with a big hole 1".how do you wire the gauge lights to work with the truck lights.,
That plate you found is for the standard trucks clutch. Perfect spot to run the gauge lines. First get a rubber grommet, measure its sealing surface and drill a hole thru the plate. Install grommet and run leads into cab. For added sealing I used the rubber spark plug lead boot around the bundle and crammed into the grommet. Tight as a ducks @##. Tap into the dimmer switch wire on the light switch for gauge light power and use the cig lighter wire for your pyro/tranny temp amplifier boxes.
Pinkston
03-09-2006 09:49 PM
TAS05CTD610
03-20-2005 08:51 AM
chrismez
10-02-2004 08:02 PM
SuperGewl
07-29-2004 09:32 PM
