gauge # 3
Those are for gassers to help show detonation. Won't work on a diesel (no o2 sensor). For a 3rd gauge (not sure what you have now) fuel pressure, transmission temp (auto trans). Turbo backpressure, boost air temp, 2nd pyro for either post of pre turbo depending on what you have now. The list goes on.
Originally Posted by displacedtexan
You have EGT and Boost, I would get a FP next.
If you get a fuel pressure gauge make sure it's electronic. Do not under any circumstances get a mechanical gauge. I know someone on here will say that theirs is working fine, good for you! I have yet to see an isolator that is any good. It's not worth the hassle, wire up the gauge and run one wire to the sending unit and your done. No isolator to fill, no hose bleeding, no leaking.
Originally Posted by nickleinonen
a/f sensor isn't a necessary item on a diesel engine. the a/f ratio on a diesel can be anywhere between ∞:1 to 10:1
Originally Posted by Boz007
Dude how did you type the infinity symbol?
Å©®σαβ±Ω∞
Then copy & paste!
Oh, electric gauges are the only way to go, for all the reasons stated above!
Tony
A lot of guys that run mechanical gauges don't run an isolator, just a needle valve they can close slightly to dampen the pulses, and close incase of a leak. And I don't recall hearing of one leaking.
Yes good for me. My isolator is fine, i have no leaks and didnt consider it a hassle at all.
Originally Posted by TonyB
Open word....From the file menu...Insert, Symbol. Look for whatever symbol you want....
Å©®σαβ±Ω∞
Then copy & paste!
Tony
Å©®σαβ±Ω∞
Then copy & paste!
Tony
Good luck with it. I had one for about a year before mine started leaking. Then I had to refill it and re-bleed it, never again.
By the time you buy the valve and the extra fittings and still bleed the line you could have had an electronic one.
sneakingawaytogobacktothe12vareas
to get ∞ and other symbols, you can use the extended characters on the keyboard
or in windows..
start > programs > accessories > system tools > character map.. all kinds of good stuff there.
or in windows..
mtl0727
10-12-2005 01:02 PM
Igor
09-13-2005 12:47 AM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
