Garrett turbo GT3782R stage 3?
Check out these guys: http://www.turboresource.com/ They start out with the above mentioned turbo and work on its shorcomings. The turbo really seems to work well, the TDR had a great writeup on it compared to a SPS62. Power came in much sooner and it was able to support a higher HP level with controllable egt's. On the plus side it is much cheaper than the above mentioned quote.
Doug
Doug
Doug
Doug
The only thing to consider when using a ball bearing setup such as the garret is their longevity, they will not last as long as say a journal bearing type turbo such as the one(s) like what HTT and II use in their turbo setups. But like stated in previous post's they will surely spool alot faster. So it's a win lose type situation IMO.
madhat's monkey boy...
so what is the actual size of this turbo compared to how most places list turbos? ex: 64/71/13 Where can you get one i didnt seem to find much info anywhere. Also what about a gt 40 what are the sizes on it. Even if it is large wont the way they say these will spool up work well for say 600-650 hp?
I wonder why these companies do not use a roller bearing to gain the additional surface area. I am sure the ball bearing would wear a grove eventually and the groove allows move and then eventually failure.
If they are replacable bearings it would be cool to see if a roller type could be used?
At 25 to 40,000 rpm any bearing play is deadly. This is the problem with the s300's under big power. Ball bearings will wear into their races as the way they make "initial" friction lower is to minimize metal to metal contact which maximizes wear when the ***** start to get out of round....and they will. I assume they are still oil bath lubricated or are they just factory greased and good to go. If they are oil lubricated with the engine oil then with all the soot in our engines you would need a bypass filter system for sure and an oil filter on the feed line to the turbo to help with longevity. ks
If the bearing is oil cooled and oil lubricated, it should essentially last as long as say main and rod bearings. And also the oil acts as a lubricating layer between the shaft, and the bearing. A ball bearing is actually riding on the shaft and is pulling double duty compared to what the typical bearing.
compare maps etc...
look at those airflow diferances...
the 3788 makes about 70lb/min max @ about 3.2 presure ratio..
the 4094 is making that much airflow at a lazy 1.75 presure ratio... it almost doubles the stocker...
yep, that looks impressive. I think I need to get one. A comment was made earlier about soot maybe being a problem for the ball bearings but I think if you are running a big enough turbo for the fuel you are using and having the smarty (or other programmer that advances timing) with the cleaner burning tunes the soot level should not be much of a problem. That being said, it would be cheap insurance to run a oil bypass filter to help out. I think the key to making a ball bearing last in that situation is going to be the quality of oil. Synthetic all the way IMO.
