full fass install question
Old 03-18-2006 | 05:58 PM
kully560's Avatar
I am just about finish ,but have a question I bought the adaptor to go to the filter houseing should I hook up to the oem filter houseing or just go directly to cp3?.I have second thoughts on the oem filter houseing because if I go directly to cp3 then I can just plug up tank hose end and cp3 fitting,and have a backup.should never need it with fass. also if I do this can I just unplug heater and water sensor and tape up ends. I do live in upper ny where it gets cold -20 will the motor have any problems starting with out heater thanks
Old 03-18-2006 | 07:04 PM
PourinDiesel's Avatar
Just go right to the CP3 if you have the FASS with filters.
Yeah, unplug the heater. You can leave the WIF plugged in (not that it matters either way).
-20 shouldnt be too bad IF you are running some anti gel.
Just watch out.
redlineguy
15
01-09-2012 10:15 PM
13bdarren
01-27-2009 01:39 PM
West Coast
07-04-2007 11:25 AM
j
11-14-2003 10:38 PM
