fueling issue truck wont stop
truck is acting crazy first sometimes when come to a stop the truck wont idle down fuel keeps pumping have to throw into nuetral to get it to calm down. also driving down the road everything is fine rail and fuel pressure wise then fuell pressure goes to 30psi and stays and rail goes to 30000psi then when let off the gas rail goes to 3000psi but truck feels fine
Mike, a lot of those dipricols have stepper motors in them. Seeing how the one (tranny temp) has already shorted out and having issues, I am wondering if what ever took it out is messing them up also. They are very sensitive and quirky with the stepper motor design. They are nothing like a normal gauge. There is most likely an electrical issue somewhere causing the gauge issue. I am not very familiar with them since they are not a line I sell. As for the fueling, that is in the tuning. A lot of the newer cr trucks have had the issue. I bet if you return the tune to stock it is not there.
DTR Advertiser
Get that thing on a Dyno!! I cant wait to see what it has.
me too Don. Cant wait to try your injectors out on a CR. I have a fuel leak I want to get straight first and figure out these gauge issues. what numbers should I expect around. Poor lmills hates this truck probably nothing is ever easy on this thing
draskobnsf
06-02-2007 12:15 PM
slivertruck
25
11-08-2006 08:35 PM
royta
11-06-2006 08:19 AM
