fueling box summary -- new VA box shipping now
#47
Originally posted by doug
correction on the VA data:
The dyno run for the VA duration box indicates 362 RWHP peak output at about 2700 rpm, and 844 ft. lbs peak torque to the rear wheels at 1900 rpm. this is for a 305.
I know you are trying to be as accurate as possible on our chart and I applaud you for that. But, If you are referencing the chart you posted on the other site (Dyno run dated 5/4/2004 which equals April 5, 2004) then the 361.7 number is definately not rwhp but is flywheel. Look at the curve labeled "Standard". Doesn't it look exactly like you would expect a good running stock 305/555 to look at the flywheel (i.e. flat torque curve if you ignore the minor hump at 1800 rpm)? What we really need is to have an independent Dyno run. That's when we will find out the real story.
The Boss Hog
(Just my opinion . . . . . . )
#48
yes I've been pondering that as well. Indeed I'm trying to be as accurate as possible and I'm suspicious that you may be right. If so, then the stock run has been corrected to approximate the flywheel HP and torque. When I get this settled I'll post an update. In the mean time I'll remove the numbers, since they have not been validated.
#50
no, but I can tell you there are three VA dealers I'm aware of:
Piers
Janetty racing
Precision Diesel Services
Dan at Precision Diesel Services (in new york. look them up on the web to get their phone number) seemed to have the most recent information.
Piers
Janetty racing
doug
04-06-2004 10:52 AM
doug
03-17-2004 02:30 AM
doug
03-17-2004 02:21 AM
doug
55
03-11-2004 02:19 AM
