fueling box summary for 4-5-04
fueling box summary for 4-5-04 includes the following changes:
* includes the new VA duration box, highlighted in grey because it actually hasn't hit the streets yet
* removed all performance data that doesn't have a dyno run behind it. Since I'm the author and am responsible to correctly interpret the numbers, I'll stick to the data that is provided or available.
* revised the numbers for the Volumizer
unfortunately no. I tell you what, though, the dyno runs I saw are very impressive. true 115 measured HP gain OVER STOCK PEAK HP. This is no "peak gain hocus pocus without any dyno data behind it. Its a steady measured 245 ft lbs torque gain from 1700 ALL THE WAY TO 2900
It blows all the other boxes into last week and makes 'em all obsolete, except for the TST. no pressure or pressure/timing box will be able to compete with this one. I have to retain some objective skepticism as to how they can accomplish such performance, and we gotta realize that production boxes might not perform this good. But they are turnin heads, and this one is going to be interesting to watch.
doug
49
04-20-2004 08:45 AM
doug
03-17-2004 02:30 AM
doug
03-17-2004 02:21 AM
doug
55
03-11-2004 02:19 AM
