Fuel Tank Vent Mod
Old 08-14-2006, 01:04 PM
iker42's Avatar
where did you order from? can you get me a link?
Old 08-14-2006, 01:24 PM
TPilaske's Avatar
http://www.innertruck.com
I ordered mine tuesday or wednesday last week and got it saturday! Installed the same day!
Tony
Old 08-15-2006, 07:45 AM
dogger's Avatar
Vent kit mod?
I installed a 56 gallon TransferFlow steel aftermarket tank on my truck and the vent is at the top on at the highest point, however goes in at a 45 degree angle just below the top plate of the tank. I imagine this kit will seal in a steel tank. Anyone with any experience with this particular tank. BOMB-ing funds shrinking.
L8r,..........dogger
Old 08-15-2006, 08:03 AM
stang's Avatar
should seal as long as your on a flat surface
Old 08-15-2006, 11:54 AM
TPilaske's Avatar
If the vents already at the highest point on your tank, then what would you need this kit for??
Old 08-15-2006, 01:38 PM
dogger's Avatar
Actually the vent mod kit would raise the bottom of the vent the diameter of the vent pipe the vent hose attaches to. The present vent pipe goes in at a 45 degree angle on the side of the tank not the top like the vent kit would. I guess my question is raising the vent 1 inch really worth it?
L8r,.........dogger
Old 08-15-2006, 01:56 PM
TonyB's Avatar
The issue is that DC uses the same tank for diesel and gasoline. Gasoline has a higher vapor pressure and therefore needs room to expand. This is the high spot that everyone is referring to and is unaccesible by the factory vent/fill system.
By capping the factory vent and relocating the filer neck vent to the highest spot on the tank, you gain 3-4 gallons of capacity and faster fill times.
Not that anyone is running a pit-stop, but the less time we spend in >100F heat or freezing cold to fill the trucks, the more time we spend having fun with friends and family, or making money!
Before the vent mod, I have spent up to 20 minutes slow filling the tank to get another 3-4 gallons in the tank, until I can see fuel in the filler neck, for a consistent fill. I would also get about 30 gallons of usable fuel (on a 35G tank) into the tank.
After the vent mod, it usually takes me 7-10 minutes to fill until I see fuel in the filler neck and I get about 34 gallons of usable fuel!
In my world, the time savings and extra fuel are worth the $35 and 2hrs of work.
Tony
welndmn
07-10-2007 07:51 AM
belgianmagic
02-10-2007 12:25 PM
jwhip
11-26-2006 12:34 PM
ramtd02
19
05-04-2006 10:17 PM
Brad02ctd
17
04-27-2006 12:28 PM
Quick Reply: Fuel Tank Vent Mod
