Fuel pressure with walbro
Old 12-30-2007, 06:02 PM
chighley_00's Avatar
I am going to try and adjust the valve a little but have no idea if that will work. Do you people think it is my dorman fitting but it is 3/8 just like the line? I don't really like the SimFlo Bypass Regulator because the internal parts look cheap. Does any one else have or used one of these?
Old 12-30-2007, 06:05 PM
trik396's Avatar
Never heard of it...
Old 12-30-2007, 06:08 PM
trik396's Avatar
Think I just found one online. Looks just like the GDP style. Not a true bypass regulator. It's going to change pressure on you somewhat.
Old 12-30-2007, 07:26 PM
JP-4.5's Avatar
The other thing to look at would be the filters. I had a similar thing happening to mine when my pre-filter was getting dirty and could not feed enough fuel to the pump. Another time when my stock filter also was restricting the flow.
The pressure would stay up fine under light throttle but would drop quickly when calling for any demand. Changed filters and all was again well.
My setup runs at 19 at idel and will go down to 17-18 when under heavy throttle.
Jeff
Old 12-30-2007, 08:13 PM
shortbed rv's Avatar
swagelok makes an inline adjustable regulator from 3 to 50 lbs. There is a 1/4 inch size part number B-4cpa2-3 and they make a 1/2 inch size.
See 8mpg DIY walbro for a picture and instruction in the tech articles.Cost me at swagelok $22.09
Jeepin4fun
12-01-2007 01:35 PM
jriggs_18
11-04-2007 04:44 PM
Sixpack73
15
07-15-2007 10:18 AM
djd220
07-12-2007 04:28 PM
CTDboy
16
01-22-2007 08:27 PM
Quick Reply: Fuel pressure with walbro
