fuel pressure Questions
I have and 06 with a 6spd. I have a bully dog tripple and i run performance and i have crazy larry but dont use it because of no fuel or rail pressure gauge. i am thinking about getting the queadzilla rail and fuel pressure set up is this a good set up or is there a more acurate set? Also what is good for rail and fuel pressures at idle and WOT and what would be considered bad?
i recently purchased the quad rail/fuel pressure guage, its a good product i just found it took a few days to get used to the little hickup in the rev when you shut it off. other than that my fuel pressure at idle when cold is 6-7 psi when warm 8-9 psi and at wot i can get it down to about 3. i was also wanting to know what are good fuel pressures as mine seem low.
Better check your gauges, everyone else has about what I have, 8-9 pounds at idle. I can draw it down to 0 though with the BDTD on extreme and my foot to the floor, a new pump in the future me thinks...
dodgeguy71
17
01-19-2012 12:52 AM
bigragu
01-24-2006 11:16 AM
mtl0727
11-05-2005 06:47 PM
darrenG
06-28-2005 07:43 AM
Flatty
01-05-2005 02:50 PM
