fuel pressure guage
Rich is right about the 0-30 and banjo bolt. I would also use an isolator so you don't have diesel inside the cab incase of a leak. You will also need a stainless steel fuel line to go from the pump to the isolator.
Where are you getting your gauge's. They should be able to help you with all the little stuff you need. Dieselmanor.com sells a great kit, it has everything. David is really good about making sure you got it all the first time.
I got a 0-30 Phantom electric gauge by Autometer and used a filter lid replacement from Genos Garage. It's a little more expensive to go with electric but the install is much easier and cleaner.
http://www.genosgarage.com/CoastalDa...D=1935&CATID=1
http://www.genosgarage.com/CoastalDa...D=1575&CATID=1
bad rammer jammer...its the same as your's but not a sport..hold on i'll post some pics..haven't gotten to it in a while.. i'm gonna run an electric guage by the way....
AM Phantom
mytrucksaslug
12-16-2007 01:11 PM
jgiachino
16
07-11-2007 07:33 PM
bigragu
01-24-2006 11:16 AM
Dodgezilla
15
03-11-2003 07:49 AM
