fuel pressure gauge...
how have you guys installed your mech. fuel gauges. where did you put the isolators? and where did you tap into the fuel source? pic would be great... thanx
I am running an isolator, but I can't seem to get an accurate reading. I used -4 hose to and from the isolator. I bled the diesel side, and filled the coolant/water side but it is hard to get the air completely out and still make the connection. I am running veg oil and diesel so I have the isolator bolted to my fuel return valve. The isolator is the blue aluminum with blue lines. It is bolted to a bracket mounted to the shock tower.
For those of you with no isolator, did you bleed the line or just hook it up and go?
dodgeguy71
17
01-19-2012 12:52 AM
Igor
09-13-2005 12:47 AM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
