Fuel Pressure ?
Fuel Pressure ?
What Kind Of Fuel Pressures Are You Seeing Under Wot. Just Installed The Fuel Pressure Gauge And It Drops Anywhere Between 4.5 And 5.5 Psi. Just Wondering What The Deal Is With The Truck. Have A Spitting And Sputtering Problem When I Turn The Tst Box Up.
But The Thing Is That It Didnt Run Out Of Fuel When I Had The Tst Box And Edge Ez On. Then I Put Injectors In It And The Truck Hasn't Ran Right Since. By The Way The Tst Box Is Setup For The Early Twins Setup.
I pull the pressure down to zero on 4x4, regular program.
With injectors, I'm sure you're pulling it down on lower settings, especially with the twins flash. The whole idea of an aftermarket injector is to flow more fuel and atomize it more effectively
Get yourself a FASS pump, and it will run better.
dodgeguy71
17
01-19-2012 12:52 AM
bigragu
01-24-2006 11:16 AM
mtl0727
11-05-2005 06:47 PM
darrenG
06-28-2005 07:43 AM
Flatty
01-05-2005 02:50 PM
