Fuel press. gauge ??
I'm in the midst of finally getting my gauges install. I have the dipricol electric fp gauge. it says to install the sending unit in the bottom of the filter housing. What about installing it in the cp3? is this possible? is it more or less acurate? going to install my airdog 150 soon and will be taking readings right where it goes into the cp3. i would like to take the reading from the cp3 now so i can compare the two later, is the bolt the same size? thanks jp
I mount them at the CP3 pump and use fittings like this to do it http://www.vulcanperformance.com/ser...-Degree/Detail
I run a big line kit from the bottom of the bowl to the CP3 pump then run a fuel pressure line to a transducer then to the gauge harness.
You have to go get a few fittings from the hydraulic shop to get it all to come together though.
Yes the fitting in the CP3 and the bottom of the fuel bowl are the same thread.
http://www.vulcanperformance.com/ser...08JIC-X/Detail
Brent.
Brent.
i have that fitting already for when i do my AD150 install, but for the next couple weeks i want to use the fp gauge, then at least be able to see the difference when i get my AD150 installed. Thanks for the info
j
05-16-2007 08:11 PM
