Fuel economy modules
although I hear reports of the Edge EZ improving mpg, I'm not a fan of it since I'm told it increases the injector pressure and cracks some injectors. I was then told that the Edge Juice box changes the duration and timing, and not the fuel pressure.
I also hear lots of good things on here about the XZT box once the dielectric grease is applied to the disconnects. Ok, after that it seems like a good box, but I also see that one of the parameters of the XZT is fuel pressure increase. Have there been any problems with cracking injectors with this box?
...and lastly I hear lots of good things about the Xzillaraider Race box, although I just read that some lose .5mpg with this box, but gain all kinds of power
So, to recap...the Boxes that are still on my list are:
Edge Juice
Quad XZT
Quad Xzillaraider Race
so, if not any of these, what would be a good box for mpg economy? right now I'm getting around 10mpg when towing...and 17-19 unhooked
Edge Juice
Quad XZT
I'd agree with Dodgzilla, don't expect the mileage increase. That being said, I'm showing a solid 1.5mpg gain while empty with my Qzilla standard box (mostly on 60hp setting) and closer to 2mpg gain while towing.
I havent been seeing any increase until about the last 4 tank fulls with my Ramifier - I usually run it in off position and have been getting in the 19 range but, for some reason the last few fill ups I have been getting 20.5, 20.8, 20.3, and 21.2 (HAND CALCULATED - I wouldnt trust that computer as far as I could throw it). I dont understand why it has gotten better except I have been doing a little more highway driving than usual. I am with Dodgezilla, if you get more power and dont LOOSE any mileage then its all good . Tell the wife whatever she wants to hear.
My last few tanks of fuel have averaged about 1.5 mpg better running on the 60 hp mode (hand calculated) driving normal...if I get the need for speed and really start putting it to it...well I think we all know the answer to that.
mpg
i had a xzt or towing box on my dodge and saw 1.5 to 2mpg increase in mileage i recently installed the race box on the first tank i saw no increase but most of that was in town 05 dodge 3500 6 spd i have two friends xzt,s for their 7.3 fords both reported 2-3 mpg increase with hwy driving for mileage i would reccomend the xzt.
Well thanks, I installed just installed the XZT w/ dielectric grease. The XZT is a fixed setting box so I just put the box under my hood with a couple of sandwich bags and zip-ties to keep the rain out...the box was mounted vertically with the zip-ties below it. Is this a bad idea? If so where's a good spot in the firewall to pass the 1" wide connector that can be resealed easily?
also, should disconnect it when towing until I get an EGT guage? The Toyhauler weighs 5000 and loaded will be around 7500 pounds...
If you will read the instructions there is a description and a picture of where to pass through the firewall.
If you are going to be pulling gauges are highly recommended.
Get that box where it was designed to live, in the cab!
Quad
well Quad, it's a good thing it's been sunny out I actually got the module used and the sticker wasn't there...
Looks like the instructions are included and intact; I'll go put
'er in the cab tonight...
Thanks Quad
UPDATE!! the box is under my dash
Thanks Quad
dieselminded
10-22-2004 12:02 AM
bwanye
08-09-2004 10:40 PM
