fuel boss or mitusa?
here is a thread i started. it has some good info as well as some links to my install pics. check it out.
https://www.dieseltruckresource.com/...l-t249992.html
Don't know about Mitusa, heard it is a good pump. But, I do know about the Fuel Boss, from personal experience. I have put over 50k miles on my truck since installing, have had no problem. Installation instructions are excellent and easy to follow. I set up my bypass valve, runs 17 psi at idle and hits around 28 psi at crusing speeds. You won't go wrong with the Fuel Boss fuel system. Excellent kit all the way around...no complaints!
start trying to get a hold of opie now and let him know your truck/mods/future plans. he will have a solution and suggestions for your application. also, he can be hard to get a hold of times, so the sooner you get on it, the better. trust me though, it is worth the time and effort you put in to get a hold of him and ask questions. he is a wealth of information and WON"T steer you in the wrong direction . . .
Termite 06
04-01-2009 09:33 AM
jmmcdona
37
02-08-2009 08:20 AM
UNDER-PRESSURE
12-28-2008 10:10 AM
Bswope
46
12-02-2007 10:42 PM
PapaSmurf
22
09-17-2006 10:47 AM
