fuel boss from GDP mechanical
Chris
the GDP BOSS pump mounts to the oil pan bolts(I think) then the pulley mounts to the factory damper..I think the Fluid damper is bigger then the factory one so it wont fit..because the belts wont line up....
I wish someone would build a boss for the CTD that mounts on top by the cp3...I think PPE makes a boss pump for the dmax's like this!!
hey all you fuel system company's.... hint hint
where can a guy buy a Boss/MITUSA pump..just the pump???
I think I may try and fab a pump mount for the pump to mount up top...like the PPE d-max setup.
I called and talked to Richard at GDP and he said they may try and make something like this but have not yet
the only problem is when you piece a homemade fuel system together it seems like it ends up costing more in the the end.....
Hey Opie, Can you give us a price on a set up to mount a second stock dodge CP3 with the Mitusa pump all on top. With the CP3.4 there is a large gear pump on the back of the CP3.4 to pull fuel from the fuel system and inject a constant psi into the high pressure pump. Ideas that need Opie quality solutions.
Both Opie and Richard are great to deal with....it is easy to get fired up on who has the website that matches your expectations best or who has the best phone system...Think ahead and longterm and the best solutions are the results. Both these fuel systems are great for the long run. Kerry
I guess???? I honestly don't remember where I saw the pic. I would just like to see one mounted up top somewhere, but then again how could you make it so that it mounts to a single CP3 set-up or a dual cp3???
I was going to try and build my own but I am pretty sure it will cost more then if I just bought a FASS or walbro kit from a vendor I really like the Boss/mitusa pumps but I really want to run a fluid damper more.
what do you think??? can it be done?? need a beta truck??
got any Links to a homebrew Mitusa pump on the top of the CTD engine without a dual CP3??? I would love to see what others have done
Thanks
I'm old school too, I really love building my own stuff...but I dont want it to be the classic saying..."why buy it for $50 when I can build it for $100"
Thanks
Thanks
No I don't have any links, but the one on the 1K hp Duramax being used with the PPE kit mentioned earlier was made by Nathan IDAHOCTD. CAPP made one for his twin CP3, I have made a couple but don't have any in stock.
mr inspector
04-13-2008 05:40 PM
BigJohnston
13
10-28-2007 09:10 PM
heavyJ
10-25-2007 09:08 AM
65pacecar
0
10-05-2007 06:06 PM
03qclb5spd
29
04-24-2007 10:12 PM
