front duallly axel.....
I have hurd that there is a spacer that can be taken off so you can run normal front rims on a dually...is that true?
steve
steve
Just unbolt the hub that extends the lugs out.The lugs that hold it on should be the same size as lugs on the extension.If you pull the front wheel off it will make perfect sense.
Yup, did it on my 03.... I don't know if the pics are still around... look up Ramasaur. If the profile is still here somewhere..... I ran 17X8 in the front and kept my duals in the rears
Gypsyman
18
10-02-2004 11:59 PM
JImbo1
04-09-2003 07:46 AM
