Front axle input shaft seal leak
Old 04-22-2007 | 10:36 PM
CamperAndy's Avatar
Just did an oil change at 15K and noticed a leak from the front axle input shaft. It would be a warranty item but before I can bring it in I need to strip off the Juice and Attitude. Then when it is fixed I will have to put it all back on again.
Would you think the hassle of fixing the seal leak yourself is more or less then pulling the Juice and Attitude off and putting it on??
Old 04-22-2007 | 11:47 PM
Jim Dynomite's Avatar
Mine is seeping a little bit also, and I have read about a few others with the same problem.
I would keep an eye on it and see if it seats itself after a few hundred miles.
Also make sure that you redirect the crankcase blowby tube so it doesn't blow directly above the pinion seal. This could be the seepage that you are seeing.
I hate taking it to the dealer also, so I would do it myself or get a qoute from a local mechanic to replace it.
..............Jim
Old 04-23-2007 | 12:55 AM
powerstrokin03's Avatar
pinion seal is what the cause was on mine. couple bucks and i was on my way. not hard to change. warranty didnt want to pay for it.
Old 04-23-2007 | 03:01 AM
Rollin' Smoke's Avatar
how did you replace it PowerStrokin03......?
mine is doing the samething, seeping really slow. would like to change it out but havent heard anyone that has done it themselves....just curious to see what you did!
Old 04-23-2007 | 08:14 AM
CamperAndy's Avatar
X2 for me. Anything special required or anything that was a real PITA??
Jim Dynomite - I saw the breather tube and it had a drop of BLACK oil on it but the oil on the axle is clear. Any suggestions on were to route the breather tube?
Old 04-23-2007 | 11:11 AM
036spd's Avatar
I was lucky with mine. I had a clunking, rear driveshaft u-joint at 35K. The dealer called me up to let me know the front pinion was leaking and if I wanted them to change it. I told them sure. When I went to pick up the truck they told me it was +$300. Nooo, the truck is under warranty. They 'did some checking', then it was covered. Good luck.
I noticed the blow-by, too. My XJ Cherokee had problems with that, I had to change out the whole tube arrangement. Fixed it though.
Old 04-23-2007 | 11:22 AM
You don't really have to, I meant it as a way to isolate the problem, but since you said it was clear oil it defitnitely isn't blow-by oil, which we all know is horribly black.
.....................Jim
DTroy
0
02-19-2006 11:40 AM
dieseljerk
07-08-2004 07:23 AM
Paul Winey
06-22-2004 08:09 AM
McGyver
08-04-2003 09:11 PM
Quick Reply: Front axle input shaft seal leak
