Found my second turbo
Old 07-19-2007, 01:53 PM
dodgezilla04's Avatar
They were going to throw this out. Its for a cummins 855. brand spanking new. wonder if it will fit wonder if i can even spool it.
Old 07-19-2007, 01:55 PM
jwb600's Avatar
how big is the inlet on that? it does look brand new. what was wrong with it anything? hope you have some head studs. I work for the railroad, I need to get one from a train lol
Old 07-19-2007, 01:56 PM
Luvnacumns's Avatar
I'll help you install it!! I wanna see this!
Old 07-19-2007, 01:58 PM
there isnt anything wrong with it, i just took it completely apart, i had to cut the packaging tape and unwrap it this morning. they bought it for a crane, then decided not to install it, the crane was being scrapped. the compressor inlet is 6"
Old 07-19-2007, 02:22 PM
DmaxEter's Avatar
Oh you can spool it............. You just need LOTS of fuel to do it!!!! I think you can do it and I think we need pictures if not video!
Old 07-19-2007, 02:24 PM
CTD03's Avatar
twins twins twins bottom turbo great pulling set up
power power power
sorry i got excited
Old 07-19-2007, 02:27 PM
i am pretty sure that this turbo would successfully separate the head from the block in a pretty spectacular manner. i am gonna call cummins nw, and try to find out just what it is. definately bigger than an s400.
Old 07-19-2007, 03:17 PM
purduepurdy's Avatar
thats not a turbo, this is a turbo
http://www.cat.com/cda/files/345132/7/lehw5314_00.pdf
I work where these are built and the turbo wouldnt even fit in the engine bay of a dodge. That one looks sweet though, yur gonna have some nasty lag with it and when it does spool itll knock the head through the hood.
Old 07-19-2007, 03:24 PM
Luvnacumns's Avatar
power power power
sorry i got excited
LMAO!!!!
Do it man!!!
Old 07-19-2007, 03:45 PM
wap
wap's Avatar
Chris, what is the displacement and hp rating of that motor?
ScienceOfSpeed's Avatar
there is another way to spool it up quick, send it to Innovative Turbo and have them swap it over from jurnal bearings to twin ceramic ball bearings, and then run it on the bottom as a compound setup,lol
Old 07-19-2007, 03:48 PM
855 cubes will. hp depends upon application. this one is 455 hp. the engines can be configured up to 525.
Old 07-19-2007, 03:52 PM
wap
wap's Avatar
How many cubes in a litre? Isnt like 61?
I was tryin to get an idea how big it is, cause I know some 12L detroits had the K31, though I am sure it is much differant than the ones guys are runnin on there 5.9s. Basally I was just tryin to figure out if you could actually use it as a bottom turbo with enough fuel and a big ol external waste gate.
Old 07-19-2007, 03:57 PM
14.01 liters. whoo hooo. just about right, dont you think?
Old 07-19-2007, 04:07 PM
wap
wap's Avatar
6" inducer?
Isnt a K31 around 2.8?
What does an S400 come off of?
Maybe you should get off of DTR and call Nathan Wright and see what he thinks. You may be on to something #2...
Quick Reply: Found my second turbo
