Ford F250 V10
Old 12-26-2009, 10:43 AM
bigwilly's Avatar
Ford F250 V10
Hey guys!! Wondering if any of you have any run in with the ford f250 v10 ? my buddy has a 2000 and got me drove nuts to hook up bumper to bumper . he said that his f250 4x4 ex cab will hall my truck apart i just laugh . so what do you guys think ? not sure what he has done with his truck .
Old 12-26-2009, 11:12 AM
Brian Lent's Avatar
He who is heavier will usually win unless lockers etc come into play. Usually they will start to hop and break a u joint so hook up to him. Don't be skeered. If you are worried put some lead in the back seat, adjust your hitch height up and give her hell. Take a video so you can put it on youtube to really rub salt in the wound.
Old 12-26-2009, 11:13 AM
STate's Avatar
I think you could pull him...but it may not be worth it if you damage your 48re. Seems to me your on borrowed time with your auto tranny with the Smarty/Edge stacked.
Scott
Old 12-26-2009, 11:21 AM
bigwilly's Avatar
so far i had good luck with my 48re i change the fluid in the trans twice year . what should i set my smarty on or should i just turn it off ? also should i take off the EDGE ? he also wants to use a 3ft or 4ft strap is this good or bad ?
Old 12-26-2009, 12:03 PM
Brian Lent's Avatar
I wouldn't want to use any thing shorter then 12'. Is his lifted that he wants to use such a short strap to pull up on your ****.
Old 12-26-2009, 02:53 PM
agregersen's Avatar
our service truck at work is a F350 V10 5spd pos and it will barely pull its self down the road. a bone stock cummins would out pull out run one any day.
Old 12-26-2009, 03:39 PM
jb818's Avatar
we have a v10 at work that gets 6.8mpg so no matter who pulls who the joke is on him.
Old 12-26-2009, 03:50 PM
lcaad1249's Avatar
The more power you have the more likely you are to lose traction.
Old 12-26-2009, 04:32 PM
RDRASH's Avatar
I have one in a e350 van it is deffinetly a controlled fuel leak. traction is going to decide who wins
Old 12-26-2009, 07:53 PM
mitternocht's Avatar
These guys are tight, traction is king. These trucks have plenty of torque to break all 4 wheels loose on asphalt. (Even the 250/460) Actually so does the Ford v10, it at a few more RPMs.
I tried to pull a stump out of the yard with all 4 on the blacktop. Stock engine, 1st gear, low range, idling I had all 4 wheels spinning. You won’t be able to idle with an AT, but the torque is there.
You need to hook up so the mount points are even, you can’t have one truck higher than the other or there will be a clear advantage to the higher party.
Definitely use low range, I’m not sure how the autos work, but I assume you can keep it in 1st gear since you won’t need a lot of wheel speed. Just hold him until he breaks loose and you’ll pull him down the block.
Now, if he shows up with a load of bricks or a mound of dirt in the back, then you better do the same.
In low range I really don’t think you’ll hurt the transmission.
Old 12-26-2009, 08:13 PM
G1625S's Avatar
It all comes down to weight and traction, IMO. You're only talking about 7-8k. Even a small block chevy has the snot to move that in low range, lol! Watch those u-joints. Seen a t-case split once as well...
Old 12-27-2009, 02:39 AM
COUNTRYBOY's Avatar
God we have a 2005 V10 here at work and it's a DOG!!!! Trust me, you could beat him stock!!! In fact I'd put my 92 W250 up against it!
Old 12-27-2009, 08:36 AM
Asher's Avatar
Singe your in Can, put a plastic tarp in your bed and fill it half full with water, let it sit over night and freeze and put a light dusting of snow over it and just say it's from the last snow fall ...
It's all about traction, the guy that breaks tires loose first is going to loose... So hook up stand on the brake until you hear his tires spin and then just pull away....
A good example of traction... Look how loaded down that ford is and look how light the rear end is on that dodge..
http://www.youtube.com/watch?v=wmU2Vgh3Lrk
And drop the air pressure on your rears to about 30psi
penguinman
02-07-2012 11:06 AM
JRD
06-22-2009 07:19 PM
dodgeguy71
05-25-2007 07:02 PM
wcbcruzer
04-27-2007 10:05 PM
Quick Reply: Ford F250 V10
