fogster install directions
can someone please tell me the connections to be made with the fogster? i bought a used unit without directions. i see an obvious power feed, and a single wire that should be plugged in somewhere and a couple fittings, presuming the headlight plug. Is the single lead attach to the fog light lead?
I believe it is the highbeam headlight lead. The fogster is to enable the fogs to work while the high beams are on as well as the low beam.
I haven't installed one so this is just a guess. Or could it be a ground?
Or just go to the company that made it and look it up...
http://www.innovadd.com/Brite.Box.In...D8.install.pdf
dodgediesel
09-01-2010 07:46 PM
autocross72
10-12-2009 10:08 PM
Sapps
08-08-2007 02:07 PM
dzpoorjr
01-18-2005 05:36 PM
cummins24
08-06-2004 03:31 PM
