Flux 6s
You guys are bringing back all those fond memories of boot popping off...when they popped off you knew you were making boost... Great to hear the new injectors are working good....I have a set of brand new injectors sitting with DonM right now...I'm letting Tim do the R&D for the Flux 6's so that my Flux 7's will be perfect. KS
a little off topic but on my 7.3 i had issues with the marine grade exhaust hose/tube boots constantly blowing off, so i had a welder run me a thin bead around the edge of the pipes for the clamps to get a better grip. worked like a charm!
Almost all twin piping has beads on the pipes. Under extreme boost it's not enough though. The set I just built has tabs on all the pipes for support bars so they cant blow apart. A boot would have to rip or completely explode. The boots are also long enough to run double clamps at almost all the connections.
bradler
02-18-2009 12:43 PM
OldSmokey
19
03-26-2008 05:11 PM
metal_miner
52
06-23-2007 02:52 PM
O.T
05-30-2007 08:55 PM
MoparRiggan
01-10-2007 03:31 PM
