Flux 6s
DTR Advertiser
Flux 6s
Got a new set of 6++ from Don to try Tuesday. They idle smooth and clean hot, & start fine. Smoke some at idle cold and you will see some haze in headlights behind you even at light throttle. I finally laid into the throttle tonight and boost went over 95lbs before I backed out of it. This was with the race smarty on 5. With my last injectors (flux 4.3s) and the race smarty on 9 my wastegates were set for about 70 lbs, so there is a lot more fuel. Truth be known they daily drive in my 04 better than 4.3s did in my 06. I am liking the 555 motor more and more as I play with it. Dyno testing to come soon then more air. Tim
Holy COW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!
Thems some big sticks right thar!!
Got those springs today Tim, you guys are fast.
Thanks a bunch!
Keegan
Thanks a bunch!
Keegan
I am having good luck with my sticks as well. Not sure on the size of mine but they seem to work well and not sure what the boost is as the boot blows off. After this next week I will mine on the dyno and all the bugs worked out.
that must be why some of those trucks in the magazines have a couple clamps on each boot that must be the only way to keep them on. you will get it worked out, it just takes time.
