Fluiddamper?
Fluiddamper?
i was wondering if anyone has or is running a fluid damper on thier crank shaft pully. i am wondering if it really helps any and weather its worth it?
Is it worth the $$$??
OOOpps,, wrong post..... the fluiddampner is easy,, just remove the stock harmonic dampner,, it just falls off, install the new one.. The belt can be a little tricky, but other than that easy as pie
Kevin
Kevin
I know a lot of guys recommend this thing and I've heard it's WAY heavier than the stock balancer. Is there any downside to changing out the stock balancer with something so much heavier (like increased wear & tear)?
