Floor it pump installed!
Finally got my floor it CP3 installed, this thing rocks! Looks like more smoke, more power, lower EGT's(unless im beating it), and a little bit more boost. Kinda wondering if my 110HP dynomite injectors are gonna be enough! Tommorow (hopefully) ill see if its droped my 1/4 times down.
It's hard to know how much it helped you until you put down some numbers I guess. My guess is that it helped but you'd know for sure if you were able to compare pressure. Does it feel any different?
absolutely, quicker throttle response, more power (didnt go WOT because i have a toolbox thats not bolted in yet in back) but i think its helped. I'm running 110HP injectors crazy larry/ez stack and idaho twins so it should help quite a bit!
I got a CEL after the install, P0088 P0148 and P0251, they were injection pressure high, fuel delivery error and i forget the last one, is this normal?
Well it went to the track today, best run was a 12.373, about a tenth faster then before but its spinning really bad in 4wd, i think thats about as quick as i can get it with the 35 at's. Best MPH at 110.44 as well.
Megaramasaur
05-05-2008 05:58 PM
Silver 002
04-29-2008 11:53 AM
Kman9090
01-12-2008 09:35 AM
cquestad
05-11-2007 10:07 AM
belfert
18
03-24-2004 11:53 PM
