Flashpaq and tire size.
Anyone running a Superchips Flashpaq able to adjust for tire sizes yet? Mine has been online once, not sure if I know how to update it though. I still don't have the option to adjust for different tire sizes. Anyone?
You can go to flashpaq.com to get help Once you figgure it out make sure to measure your tires from the ground up it will not be correct if you just set it to 35 bcos thats what size your tire says
Another quick question, will updating change anything in the Flashpaq that I need to worry about? Can I leave the stock program in the Flashpaq and leave my truck set on Performance when I update? Thanks.
yes, you can leave the program loaded in the truck and the stock one in the pogrammer. If you download the flashpaq utility and update your tuner, you should be able to adjust your tire size. although, i thought their first version you were able to adjust the size. i would hook it back up and scroll through the menus and make sure that it is not there. but the latest update allows you to turn your high idle on now too...
It's on there. Even the original program allowed you to adjust for tire size. But like pooperscooper said, you can enable the high idle feature with the latest version and also does data logging. Go ahead and download the new update and if you have problems pm me and I'll help you.
strucksvt
03-15-2008 08:56 PM
js091899
03-01-2008 09:26 PM
bigdogtruck
18
11-21-2007 08:09 PM
