Flameball shifter knob
Old 03-11-2005 | 09:02 PM
kcbarnes's Avatar
Flameball shifter ****
I thought I would put a pic of it in my member gallery. It was bought at www.flameball.com and is lighted by a led on the inside.
Old 03-11-2005 | 09:16 PM
MikeyB's Avatar
Cool!
MikeyB
Old 03-11-2005 | 11:13 PM
bkrukow's Avatar
I like that. I may have to get one as well.
Old 03-11-2005 | 11:40 PM
Buckshotmckee's Avatar
Cool! When I was looking for a gear shifter, covers/replacements I couldn't find anything like that so I had to impravise. I got a piece of Buffalo hide on the shifter and a Deer *** **** on the transfer case lever.
Old 03-12-2005 | 07:48 AM
MikeyB's Avatar
After visiting the flameball website I may go with their 2 1/8" solid ivory color shift ****. Seems like they supply the correct thread insert and jam nut for our 10mm x 1.5mm shaft.
MikeyB
Old 03-12-2005 | 08:06 AM
kcbarnes's Avatar
Flameball was a pleasure to deal with and a nice product. the only thing I would have done different was ordered it without the hole for the light predrilled as I was able to run the wires up the inside of the shifter to hide them and put the led through the treaded insert.
Old 03-12-2005 | 08:33 AM
030303's Avatar
Anyone know the size of the transfer case **** threads? Thanks, John
Old 03-12-2005 | 03:15 PM
kcbarnes's Avatar
030303,
When I ordered mine I just told them what make/model I had and they took care of supplying the correct thread and size.
Old 03-12-2005 | 03:50 PM
502502's Avatar
They are the same as the shifters thread... They use the same shofter **** on both
(at least on 3rd gens)
Old 03-13-2005 | 08:27 PM
kcbarnes's Avatar
Just thought I would let you guys know that I have uploaded a daytime pick in my gallery.
Old 03-13-2005 | 08:41 PM
snapp919's Avatar
I got one from jeg's, it's a hurst shifter ball that has the same shift patern as the 6 speed, although you will have to buy a reducer to get it to fit the thread. I have pic's in my gallery.
Old 03-13-2005 | 08:55 PM
Original Junior's Avatar
snapp919, where did you get the reducer at? You have exactly what I wanted. What is the diameter of the Hurst shifter?
Old 03-13-2005 | 10:25 PM
snapp919's Avatar
Original Junior, I had originally ordered the ivory ball from flameball wich came with about three or four differnet reducers. The ball wasn't really as big as I thought it would be and had a yellowish tint to it and didn't match the instument panel. So I ended up buying the husrt 6 speed shifter from jegs (16mmX1.5'' thread size) part#530-163-0016. Luckily one of the reducers that flameball had sent fit it perfect. You might be able to call them and order just a reducer for our trucks or if you know of a place that would sell such a reducer. I don't know the actual diameter of the hurst ball, but it does look just about perfect for our trucks. I have gotten many compliments on it.
Old 03-14-2005 | 01:02 PM
MikeyB's Avatar
Snapp919, looks good!
After seeing your Hurst **** installed I decided to go with it. I'm having a machine shop make a threaded insert for me.
MikeyB
Old 01-17-2007 | 03:43 PM
reb0957's Avatar
KCbarnes
How did you run the wiring inside the shifter? Inquiring minds wanna know!
