First Dyno Run
First Dyno Run
Finally went to my first Dyno Run in Monroe,WA. Pretty awesome...some of the trucks were pretty darn powerful! One ran 850+/1500+.....I was quite amazed. I also managed to get my BONE Stock numbers for my truck.
258/479.......I thought Dodge advertized them with 600 Ftlbs of Torque....what happened to the rest of it?
Location: From Texas; Staioned in WA; Transplanted to AZ
Something's not right there... I had an intake, removed baffles and silencer ring and put down 275/515. The only difference it appears between us is yours is a DRW.
BTW, how come I didn't know about a dyno day? I was bored all frickin day today.
Oh yea, the 278/521 in my sig was a run that did HP only, I just used several math equations to get the TQ, but the numbers I put above was when they figured both. (Both runs at DDP in Monroe)
DTR Advertiser
Hey Bubba, Did you catch Scotts numbers at the Dyno Event? He has a 03, Standard Output with a TST , the killer B-2 turbo and set of Flux injectors. He cranked off a 508 HP run. Uncorrected! All the days numbers were run uncorrected on a DynoJet.
That IS the highest SO dyno number I have ever seen with that combo of parts.
It was Level 9/9, BTW!
Don~
Don~
It was a Dynojet and it looks like my numbers are about right for a dually. Now, I have a baseline to bomb from. I would like to thank the guys at Dyno-mite Diesel Performance for putting on the show......especially the 800+/1500+ run, that was AWESOME!.
Ghostrider even made an appearance......it is a really nice truck in person...unless he gets it lost in a snowbank!
Originally posted by cr25ovet
was it a dynojet? if it was a mustang dynamometer the numbers will read lower
Don~
Don~
It's interesting to see him put that much out on those high levels... most I've seen they start to go down after level 7. But I guess with all his other goodies it compliments it and helps it out.
Don~
Don~
Scott emailed after he ran, and I think he told me on 5:5 - he pulled 417
then run it up to 8:5 (to save the stock clutch he left the torque alone) - He netted 503 hp...
Though I'd point it out because he and I were talking, and if he had an aftermarket clutch and a pusher pump and of course would put the TST to max, I would have to wonder if he had another 30-40 horse still there (with Flux injectors and all)
What do you think don?
Whats the high on a single charger?
DTR Advertiser
Yes, you are right Tommy! The last time I spoke to Scott on the tele he did not have any pressure box. I told him to run on 9/9 so I assumed he still had the same combo. 9/9 gives us the best power with the TST by itself using the Flux injectors. Ading some pressure can change that. I dont know what the best setting is with his pressure stack.
Thanks for clearing that up!! I was surprised in the numbers. 500 plus from a Standard Output 5 speed is rockin'
Yes, Im cetain there is more. BTW, his EGT was lower than his stock injectors. He reported somethig like 100 less in cruise and 200 at WOT! If my memory serves me right!
Don~
Don~
Why would a dually have more drivetrain losses? It's the same drivetrain components as a SRW. The only POSSIBLE difference I can see might be that the extra wheel/tire has more weight, so it could affect the readings from inertia. But, I don't see it making 20+ hp difference, and inertial losses pretty much disappear anyway once the vehicle is at a steady speed.
DTR Advertiser
The dual wheels take away anywhere from 20 to 35 HP on a DynoJet. Add a transfer case and it gets worse. We have tested it all on the Dynojet. Its how fast you can spin the roller. The less weight you have to get spinning, the better.
The best truck to have for dynoing is a 2WD, single rear wheeler.
Oh big tall and heavy off road tires make it even worse.
Im stuck with a 4x4, Dually myself.
Don~
Don~
