Finally found a combo for 11's
Old 07-24-2008, 10:52 AM
06MegaCTD's Avatar
Cause corrected i think your truck ran a 10 second pass
Old 07-24-2008, 11:58 AM
Hintz's Avatar
Thats Fast
Old 07-24-2008, 12:17 PM
12valve's Avatar
Sounds good!! And they say the stock/s400 is only good up to 650hp
At what elevation is that? Are you spraying nitrous?
Old 07-24-2008, 12:26 PM
06MegaCTD's Avatar
if that was a race in the mountains i am guessing that was at least 4k feet elevation and if the weather was in the 80's his time converts to a 10.57@128. Now that is something to be extremely proud of
Old 07-24-2008, 05:51 PM
OutOfSight's Avatar
5800 feet at bandimere speedway. No nitrous, just fuel on a stage III pump. I know at lower elevation it would do better but since its a forced induction motor It wont be that much difference I dont think. Judging by a trap speed HP calculator I'm making 745 to the ground, I'll have to hit the dyno up soon!
Old 07-24-2008, 10:03 PM
lit up's Avatar
OutofSight- Great run. Do you have RP gauge? I'm just curious because I'm running a Stage 3 from II and I still cannot maintain rail pressure. Just wondering what pressure your running.
Old 07-24-2008, 10:18 PM
06MegaCTD's Avatar
i am pretty sure that it still does effect your times forced induction or not.
Old 07-24-2008, 11:39 PM
Big Blue24's Avatar
Stang, Times will obviously improve at lower elevation but that calculator you're using has too high of a correction factor for a turbo diesel application. I could see him dropping a tenth or three but not 1.2 seconds.
Now a naturally aspirated engine, altitude and temp will really kill HP and thus you could have a 10% correction factor. IIRC turbo forced induction motors are less than half the correction factor of a NA induction motor.
Old 07-24-2008, 11:50 PM
06MegaCTD's Avatar
yeah i did some reading and realized that it doesn't effect turbo vehicles as much as a naturally aspirated engine so i was wrong, but under what other people are telling me corrected he is a little over 3 tenths faster at sea level.
Old 07-25-2008, 01:03 AM
Idaho CTD's Avatar
I would usually lose around .2 sec from here in Boise to RMR in SLC. There is about 1800' difference in the tracks. From here to sea level it is .1 second or less. So I would guess Allan would run at or slightly under 11.5 at sea level.
Old 07-25-2008, 05:30 AM
OutOfSight's Avatar
Yes I have a RP guage, no problem what so ever maintaining RP!!
Old 07-25-2008, 09:42 AM
cquestad's Avatar
The calculators do not work so well on turbocharged vehicals...
NICE RUN!
Old 07-25-2008, 09:59 AM
Stainless's Avatar
I still think you should try a run with my smarty, I was there and had it with me but didnt get a chance to catch up to you guys. I was a little to busy buying go fast parts. But those are some really nice times!
Old 07-25-2008, 04:19 PM
OutOfSight's Avatar
Thanks man, yeah john at floor it is pushing me to try a smarty and a custom pressure box, ill be giving it a try lol.
Old 07-25-2008, 10:24 PM
OutOfSight's Avatar
To give you guys a idea about johns stage 3 pump were holding almost 27,500 rp
Quick Reply: Finally found a combo for 11's
