Finally decided on which set of twins
Ok I decided to go with Nathan's twins. Its a HTT 62/71/13 and 80mm S400 any opinions or suggestions on this set?
Its 5600 for the kit, and 200 for high temp ceramic coating on all the hot pipes, manifold, and S400. Plus I decided to have the top turbo ordered with the polished housing (an additional 100 bucks).
That is the turbo that I'd use on any future set of twins? Is Nathan spec'ing a bigger wastegate capacity or is it an external waste gate setup... If HTT has enlarged the wastegate capacity ...this is a turbo that will rock with a good s400. You are making alot of people jealous. ks
WORk !!! No really... I do construction.. Complete home re-make-overs.. Like you see on tv!! Not easy stuff!! I have been pretty fortunate and I am thankful for that!! Life is what you make it!
Like 97 asked, are you reusing the stocker or using that A5K?
Yes stock turbo.. I can upgrade to the 62 later but for now Nathan says the combo should get me a little more on the dyno and make like soooo much eaiser towing..
Yep that's what I would do.. Working on a 7-8000 sq ft house right now.. It's four stories!!
