Fella Sac'rs
Fella Sac'rs
just loaded my new smarty Sr yesterday & WOW!! run'n #3 now & max try @ #7 4 only 5min.
Had a full run 2 day & noticed coolant temp takes no time 2 spike normal dose that have any thing 2 do with EGT's cuz 05's run non conductive intercoolers[PLASTIC]
PS any more room 4 a potential SAC'R
THANX
THANX
It will warm up quicker due to the added fuel. On my truck it will stay just below the middle mark, but when I give it a hard run or pass someone it will jump right above the middle mark... never goes past that though.
I just got mine yesterday and I have to say, I'm not blown away on sw 5. I do have a california truck, but I was under the impression that the new software would bring it up to the same level as the HO trucks, and then add power. Truck is waaaay faster than it was, but it was a slug. I launched it pretty hard today, no smoke and a weak 2nd gear scratch. It did start rolling coal in 3rd though, maybe I just don't know how to drive. I am on 35s and run a pretty tall rearend, 3.73 I believe. Should I try a different software?
I'll definately check sw 7 out, but I was actually referring to different versions, like the 4.11 moderate tqm and whatnot that everybody on here is always talking about, but I think I read on one of these threads that the latest release (Dec. 07) smokes less than what it was shipped with. So far I really haven't been able to wrap my brain around all the different softwares and versions and stuff.
madhat's monkey boy...
If you want smoke, go wild torque management. It will guarantee a big ol' grin and a ton of smoke right off idle. You will only be able to do it a couple of times though without a clutch. Load it once and try it 1 time and you will see. The clutch will be on the priority list then so you can harness the power.
I am on 35x12.5's and I had Smarty on sw9 and the MP8 about 75% and romped her in 3rd and it just lit up the tires. I then jammed 4th (about 35-40mph) after it bit in 3rd and the rear end scooted out on me once the turbo lit in 4th.
Pretty nasty
Pretty nasty
Try the stock injector/aftermarket turbo program.
MikeyB
That's a big negatory on the boost elbow, which is simply a copper elbow that threads into the wastegate on 03-04's right? I read about it on here somewhere but don't really know much about much
Pretty nasty
Pretty nasty
well heck yeah! it's 80-85 degrees year round, the suns always out, the fish are always bitin and worst of all, there is always a cool breeze coming off the ocean. It's downright miserable here.
