Fast Clutch??? 6 or 12 button??
#33
Way to get our heads spinning again Mark!!!!!!!
I have been looking at the 3850 DD simply because I want a clutch that will hold up to almost any condition that I can throw at it.
That being said I also want
1. A "streetable friendly" clutch
2. A strong, virtually unslippable clutch to 700 HP
3. A fast shifting clutch
4. A good strip and sled pulling clutch
I guess its another one of those things that just takes time and research to figure out.
Chances are whatever clutch you buy, you are probably going to wish you would have tried another...... Not saying that the one you have is bad or not right but that is just human nature (atleast for me)!!!!! AAAAARRRRGGGG
Doesn't D.WIGGS have the 3850????????????????????????????
Maybe he can help us out at somepoint, he has to be up near where we want to be with H.P. Rating
#35
I am pretty sure if you want to sled pull you gotta get a 12 button...all the 6 buttons seem to be more for drag racing then sled pulling.....Peter told me I could sled pull with the 6 button...but if I am gonna do more drag then sled I should get a 6 button.....I guess thats what I should do Peter IS the expert after all sled pulling seems like it's 10x has harder on your truck then drag racing..and I dont see many sled pulls in my area.. the RMR track is only 30 mins from my house....So drag racing seems like the most logical for me
Plus sleds have been known to take g56's and turn them inside out
I already have a sport where I go out and break stuff..it's called rockcrawling.
yes I know drag racing is hard on stuff too...but it seems to be the lesser of two evils
#37
#39
Well after a lot of headspinning and going back and forth
I have decided to get the Haisley Machine Street Drag Clutch...I have talked to Banshee and he has nothing but good to say about the HMR street Drag and his 1/4 mile times with a HMR equipped handshaker has gotta mean something I am sure I would be happy with either the HMR or the SBC but I think the HMR is more of what I am after. it will be a couple months before I can buy it...thats sounds like a good Christmas present
yep, Haisley Street Drag 6 button here I come
thanks for all the info and opinions you guys had...cant find a better review comity then the DTR gang
Thanks to all
Thanks to all
#40
Reducing pucks on the clutch faces can aid shifting faster but it does greatly reduce the amount of power a clutch can hold in my opinion. Your basically taking away half the friction properties of the clutch by going with a 6 puck unit (thats 6 pucks per face which means you get 24 pucks total where as with a 12 button DD you are getting 48 pucks total)
South Bend's DD line is awesome overall in my opinion...
However I would not say they are necessarily fast shifting at least for my truck/abilities. I run the 4200lb currently but over the years I have ran the 3600 and 3850.
With my current clutch I have about 23-24 hooks to the sled with it and thats coming out at 50-60psi @ 3700rpm in 2nd gear/hi range.
#41
Aren't the buttons in a 6 or 12 puck clutch different sizes?
Given that they consist of the same friction material with identical plate pressure, what does that say about their respective maximum theoretical steady-state torque capability?
Interestingly, in the case of an engine transmitting 1K lb-ft of torque through a 6 button single disc clutch (with an arbitrary 1.0 coefficient of static friction) and assuming 3" square pucks centered 6" away from the input shaft centerline with homogenous power flow:
each button must hold about 18.5 lbs/sq"
For a 12 puck:
each button must hold half that
For a 6 button dual disc:
each button must hold half that as well
For a 12 button dual disc:
each puck must hold half that again - about 4.6 lbs/sq"
Since the buttons in a 12 puck could be smaller, giving the clutch better innate cooling while still having superior holding power - let's assume a 2" square puck in the above package.
For a 12 button single disc, 1000 lb-ft torque engine:
each puck must hold about 20.8 lbs/sq"
each puck must hold about 10.4 lbs/sq"
So, it's clear to see why 12 button clutches hold more than 6 buttons, and why dual discs hold more than single discs - more "swept area".
Now, who knows what the different puck sizes are?
For a 12 puck:
#42
Thanks for the posts gentlemen...very good info & points.
I am not too worried about the 6 button holding big power, Banshee is putting down just shy of 700hp and he has yet to slip it/over power it.
The HMR Street Drag is a DD clutch. Honestly I really doubt I will do any sled pulling and this clutch would still let me "Try it" once or twice if I wanted...and if I got hooked then I would maybe change to a more pull friendly clutch. There is way better access to the Drag strip Vs the Sled were I am at anyway, I have never even seen or heard of a truck sled pull in Utah.
#43
So will the Hasiley DD hold up to boosted 3rd gear launches?
If remember correctly I dont think Banchee does 3rd gear boosted launches.
Is there a correct way to boosted launches and burnouts without welding the 2 surfaces together and hurting the clutch.
#44
I the think the better question is, will a ANY 6 button DD clutch hold up to 3rd gear launches????????
#45
I bet you can do them with the G56...the gearing differences between the NV and the G-unit might be why....from what I gather Banshee has not tried it cause the gearing with his 35's would bog it down...all tho you would think 20lbs of boost would cure that maybe he will chime in on this one.....
I dont build more than 5lbs of boost but I can power brake my truck in 3rd on dry pavent with no clutch slip, but I do have the 12 cb.
My next tires will be 35x12.50s and I will see if I can powerbrak 4 of them, slip the clutch or bog the motor down.
