Fass Pressure
Fass Pressure
Is there a way to get more pressure out of a 95gph fass pump? My truck idles at 16psi, but drops to 5 psi at WOT. I would like to keep it around 15psi at WOT, any info?!
No prob!
You can have a big motor with the 95gph flow rate(150/95) or you can have a small motor with 95gph flow rate also(95/95) The reson I ask is you can get more pressure out of the bigger motored pumps. I run 40psi out of my 150/95 right now, with just a spring change.
Are you running any other mods? I have the Fass 150/95 and it too is at 16 psi at idle. I can't pull it below 14 or so at WOT, but I'm pretty much stock (no fueling enhancements). Oh yeah, I am also using a 3 micron fuel filter.
At idle you dont want over 20psi and of course WOT you dont want over 20psi.
Best thing is a higher flow pump you would have a low pressure (ie 15psi) that will stay consistent under a loaded condition.
rjm022
07-08-2006 06:30 PM
Buckshotmckee
05-23-2005 12:08 AM
Flatty
04-25-2005 12:49 PM
