Fass Fuel heater?
Fass Fuel heater?
Anybody running a fuel heater? The fass diagram shows a port I never noticed that is labeled as fuel heater. I think I would feel alot better about removing the grid heater if I had that.
Then again wasnt there an air remover of filter or something that diesel power was advertising that also had a fuel heater that clamped inline?
The FASS fuel heater is coolant based so you need to run a coolant feed and return line....The FASS circulates alot of extra fuel which warms up the fuel on its own....I've started the truck at -40 with no grid heaters.....The only time I wasn't able to start the truck was when it was -26 C and the truck hadn't been driven in a couple days...and the batteries were frozen...I hooked up a hot battery and it started on the first second of crank...with some Howes and isopropyl antigel. If the FASS can pump it the truck will burn it...Kerry
JJK98CTD
03-29-2009 10:45 AM
rjm022
07-08-2006 06:30 PM
