FASS Filter Mount
FASS Filter Mount
I received my order and opened it up to find the most micky mouse mounting system I have ever seen. For $650.00 I certainly expected
considerable more on the design side of what is going to hold this on. I would liken this to an anchor at the end of a fishing pole method.
Has anybody else had any concerns with only (2) 1/4" bolts holding the entire assembly to the truck?
The dealers response was "lot of them out there, havent had any problems".
Considering whether to return it or not...
OK, I went back and opened up all of the hardware bags (Should have done this first ) and layed out the parts. Once that was done it became clear how everything mounted. The aluminum spacers were the key as I did not see them the first time. Yes you are Correct Dan (5) in the unit
(4) bracket to bracket and (2) bracket to frame.
Constructive comments...
1. The bracket arrangement I have is not shown anywhere in the Instructions I received in the box.
2. When the instructions refer to the actual mounting of the bracket to the pump unit it refers to photo 2A....2A is a photo of a hose being placed on a barb on top of the tank?
You are correct about the 2A photo....i will bring this up with Brad...we are currently redoing all our manuals.....thanks for the help!
J10495T
09-21-2011 04:07 PM
ollie32
06-03-2007 09:29 PM
danc46
01-06-2007 05:24 PM
chw
12-25-2006 04:30 PM
