FASS and Factory Warranty
Just put the FASS on and enjoy better filtration! The stock filters are marginal at best. It really will be one of the best things you can do for your truck just for the better filtration not to mention the improvement in fuel pressure/volume. When I put my Glacier pump on I noticed a slightly smoother idle and a little better response.
I see in your signature that you've got a K&N intake. I don't mean to sound rude but I personally don't like K&N filters because they have been known to dust the engine. Some have been able to run them successfully but I don't trust them. I've seen more than one dusty turbo due to a K&N! You can get an Amsoil nanofiber filter that will replace the K&N with much better filtration and you can still use the intake. Again I'm not meaning to sound rude but, like most on here, I like my truck a lot and don't want marginal filtration to reduce the life of my engine (more than I'm going to reduce it with Smarty anyway).
I've heard great things about the FASS Fuel Systems! As of warranty issues I believe it would depend on the dealer. Dealers around here try to void waranty issues if you change your own wipper blades. Sell it to me if you don't want!!!
I am about to find out if my local dealer will void my factory warranty due to a F.A.S.S. I noticed today that my CP3 is leaking. Going to make an appointment to have it looked at as soon as the holidays are over. Wish me luck!
I know my dealership told me to **** off when I took my truck in for the 5th time with Injector issues.
What really ticks me off is I was having these problems before I put the FASS on and it had been to the dealer 4 times without the FASS, and I put the FASS on to see if maybe it would help.
They basically used it as an excuse to not warranty my injectors.
WAY too late for that now.. LOL!!
But thanx for the thought.
I figure they were just looking for excuses.. Eh Well. It gave me an excuse to go with an aftermarket set of injectors..
If I could find the name and contact info. for a Dodge Dealer that sells them, I would use it to build a case in the event my local dealer tries to use my F.A.S.S. as an excuse to void my warranty. Does anyone know of any dealers that sell them?
deerefarm06
07-18-2007 05:41 PM
ASTAR
07-06-2006 10:25 AM
