Fass Blowing Relay
Fass Blowing Relay
This is the second relay I have replaced in 6 months. Shuts the whole pump down, 0 pressure on the fp gauge. Amazingly the rail pressure seems to be ok, guess the cp3 can still pull enough fuel. Any thoughts where to start looking for the problem.
Check how you have the wires connected at the relay and at the Fass, make sure your trigger wire is not tied into the load wire, and vise/ versa. Also check the spade connectors for a quality connection, look for any corrosion or hardened wires.
Re post your findings,
Tim
Tim
Looks like relay was geting wet with wiper fliud. The position is on the firewall drivers side. I will use electric tape around the relay until I figure how the wiper fluid is leaking down the firewall.
06dmc
08-28-2006 01:29 PM
mazeppa
02-10-2004 07:54 PM
