Fass 150 on a 06
Thanks! i suppose thats the part number, or? ill see if i can get it at the new napa store in town...
Indeed. I heard the FASS and the Airdog were pretty much exactly the same, just a father and son having a urinating contest with companies. So if the FASS tech recommends it as a must, ipso facto, you get it.
Got the strainer...
I have a problem now, like i mentioned i made my own special quiete mount. and it was pretty quiete too...
now it starts getting very noisy (the pump itself) is that a common problem with the fass?
what does that indicate?
WELL.....did you put a draw tube in the tank? OR are you pulling through the in-tank pump?
is there some kind of overflow valve that would make this noise, or return too uch fuel, cuz i was surprised, now that i put aon a fp gauge, it reads 16 at idle, and pulls down to 8 psi on at WOT kill.
is there a way to know if the pump is bad, or to adjust the pressure for more pressure, cuz i bought it for a 150 gph pump and i thought they are all 45 psi.
rjm022
10-20-2014 02:29 PM
CrashCade
12-03-2008 07:58 AM
dodgediesel
26
11-02-2008 12:20 PM
curts99
02-14-2008 12:09 AM
Ramtuff06
08-21-2007 06:21 AM
