Factory mud flaps rubbing paint?
2 guys I know have them and they are rubbing off the paint where they meet the body. Any recommendations as to some clear stick-on plastic I can put on so the flaps rub that instead of the paint. I've seen (what looks like from the factory) plastic stick-on pieces on certain cars in the rocker area, usually right behind the wheels.
When I put the flaps on my 05, I put some wide double sided tape on the flaps where it would be touching the body.
That way its protected and sealed from anything getting between the flaps and the body.
Just an idea for you.
1. Put double stick tape between the rubber and body part.
2. Put a layer of clear tape between so the rubber and dirt rubs against it; should be able to find it at most places that sell auto parts.
3. leave a slight gap between the body part and rubber. Of course it doesn't look as good close up as a tight fitting molded mud flap.
I just washed my truck saturday and got to looking and wow my paint was missing too. I should of thought like you guys and put something behind it. Stupid me. You think dodge will cover that under warranty?
JaredOlsen
05-26-2007 12:23 PM
Original Junior
09-29-2005 03:27 PM
rjm022
05-06-2005 10:56 PM
moopa
05-02-2004 08:46 PM
