F1 springs, I need a set
Old 06-16-2008, 10:34 PM
  #31
dodgezilla04's Avatar
ok buddy. have fun with the install. mine's gonna start next week sometime. and a few other items
Old 06-16-2008, 10:55 PM
  #32
O.T
O.T's Avatar
Chris, sounds like your staying busy and getting dirty
Motor is coming together, have all the components waiting on connecting rods..should be running end of July
Old 06-17-2008, 01:04 AM
  #33
tristan21's Avatar
Havnt been following, what size inj. are you installing will?
Old 06-17-2008, 06:52 AM
  #34
wap
wap's Avatar
Looks like the tool wont be here till Monday, so I guess Monday night the springs will go in, and as soon as some more molly lube gets here for my arps I will finish them up, then the injectors, Tuesday night if they are here.
Tristan, I am goin with the 2.5s for now. I know its a bit much but since my next mod will be dual cp3s I am hopin to cut the electronics way down and get by until I can get the the pumps. I now 750 is possible on the 2.5s so I hope that is big enough, but if not I wont need bigger injectors until after twin turbos and twins turbos aint happening anytime soon. Hopefully I will never need/want anything bigger than the 2.5s, but time will tell.
Old 06-17-2008, 02:40 PM
  #35
12valve's Avatar
thanks for explaining that! I thought the revo/tnt would pull to 4000 rpm, but it doesnt! lets see how much boost the mpi's will make... to see if its necesary...
Old 06-17-2008, 03:13 PM
  #36
Billy Ram's Avatar
The TNT won't but the TNT-R will.
Old 07-09-2008, 11:59 PM
  #37
blwnsmke's Avatar
Can the F1 Sportsmen springs handle the TNT-R?
Old 07-10-2008, 06:54 AM
  #38
wap
wap's Avatar
absolutely
Old 07-10-2008, 09:59 AM
  #39
DTR Advertiser
Don M's Avatar
Yes, unlimited boost and unlimited RPM. They have been spinton tested to 11,000 RPM!!!!!! We can also simulate boost pressure.
Tim Barber has run his Common Rail past 95 PSI boost pressure and 4000 RPM with no valvetrain stability issues. Many others as well.
Old 07-10-2008, 02:34 PM
  #40
blwnsmke's Avatar
Ok well I bought the set off of "OT-OF-HERE" so I just wanted to make sure I could run tnt-r. I have a early 04 head. Is there anything else I should change out on the head to be safe spinning it that hard? Truck has 95,000 miles on it..
Old 07-10-2008, 04:55 PM
  #41
BossHogg's Avatar
Try Timvia, he shot me a good price but I ran outta diesel dollars...happens everytime I get a price from him...I dont know why.
Old 07-10-2008, 05:15 PM
  #42
wap
wap's Avatar
If you there you really aught to do studs too, and you gota pull injectors to install springs so I would consider doin injectors too if you got the coin. Even with stock sticks, if you are runnin a stock turbo you are gona blow past the waste gate with that stack.
Boss Hogg, I got my injectors from Tim and would of gladly gotten springs from him too but he was out when I needed em.
Old 07-10-2008, 05:24 PM
  #43
blwnsmke's Avatar
I bought his studs to! Im about to do studs, springs and injectors.. I meant anything else like should I freshen up the head.. Any different or better valve seats for early 04 etc..
Old 07-10-2008, 06:08 PM
  #44
wap
wap's Avatar
I dont know with the 04, I am sure it would be a good idea to stake the vavle seats but if you are not pullin in the head I dont know if I would or not. You could alway port and polish but I have no experience with that.
Old 07-10-2008, 06:45 PM
  #45
blwnsmke's Avatar
What do you mean by stake the valve seats?? I am pulling the head and going to change the head gasket since Im that far when I do head studs. I was thinking of a little port and polish too. Maybe like a gasket match port job
Quick Reply: F1 springs, I need a set
