EZ to Smarty
DTR 1st Sergeant
A lot of difference... a lot more power for sure...
You'll see. Just be sure you don't overdo it at first. Smarty's lowest levels will be close/more than EZ's top level.
The EZ is a pressure box... meaning its power came only from pressure (and a slight amount of timing) Smarty will do duration, timing and pressure. All of those are user selectable to a degree.
As you go up in SW levels, that increases duration. Within the menu you will be asked to select options. There you can mess with timing and pressure as well as torque management.
You're gonna hate that you didn't do this sooner, then you'll hate how much more $ you have to spend in upgrades.
stock03
34
04-21-2011 07:40 AM
RyeThomas
40
04-20-2007 10:12 PM
CTD_Neil
02-23-2006 09:27 PM
