Exhaust Swap Problem
AMEN BROTHER!
Messed with it for about 5 minutes then broke out the sawzall and spent a solid 5 more cutting it off! If you're paying to get a T-304 system to replace the original, quit ***** footing around and cut the old one up. You'll never use it again anyway.
Cheers
Mike
Cheers
Mike
Mike
you should be able to loosen your clamps and move it closer to the bed. that should be all you will have to do. I have a small magnetic level that you can set on the pipe to get it exactly level if you want
Unless they can prove that part caused your other part in warranty question to fail then they can not void your warranty. My suggestion is that if they are hassling you over an exhaust sytem find a new dealer. Our dealer has a dont ask dont tell policy.
bigwheels94
07-11-2008 03:10 PM
Treangen
63
07-07-2008 07:42 PM
justagoodolboy
09-06-2007 12:31 PM
