Exhaust Brake Switch - What Switch and Where
Old 06-19-2014 | 08:46 PM
FordTrax's Avatar
I am looking at putting an exhaust brake on my 2004.5 Dodge CTD. It has the 6 speed manual tranny. BD offers a toggle switch or the plunger style for which mount on the manual tranny shift.
I was wondering what you folks are using for switches and where you are mounting them? Toggle, Plunger, etc...? Shifter, dash,...?
Old 06-19-2014 | 09:09 PM
seafish's Avatar
Have NOT had time to install my EB yet, but when I do, I will mount a push-pull switch on the stick.
On the stick REALLY is the most convenient place to control the EB from on a manual tranny.
Old 06-20-2014 | 09:58 AM
soulezoo's Avatar
DTR 1st Sergeant
You have a stick, definitely a plunger on the stick as mentioned above.
If it were an auto, then the toggle on the dash.
Old 06-21-2014 | 08:43 PM
john40's Avatar
On my last truck, which had a stick shift, I had a push pull switch on the shift lever. This was convenient and worked quite well. On my current truck, which is an auto, I installed an "old time", floor mounted dimmer switch. This is also convenient and is "hands free".
John
Old 06-21-2014 | 08:48 PM
Mexstan's Avatar
For many years now I have used a small round toggle switch mounted on the gear shift. When I want the brake. I just hit it with my thumb. Use the thumb again to switch it off. It works great.
Old 06-22-2014 | 06:11 AM
FordTrax's Avatar
John
Interesting idea. Unfortunately I am old enough to know exactly what you are talking about
Old 06-22-2014 | 08:51 AM
Festus's Avatar
Please disregard my ignorance, but I am not following.
What is the reason why needing the exhaust brake switch so accessible and hands free??
I turn mine on after starting the truck and it stays on until the truck gets shut down.
Now for ice or something emergent, I have a clutch switch so moving the clutch pedal a 1/4 inch turns it off and I can just move my hand to turn the brake off. I can see having a handy switch to disengage for an automatic, but it has been quite a fee years since I've had to worry about that side.
To keep on topic of the thread though, my switch is remote - no wires running into the cab. I have a four button key fob velcro'd to the headliner side of my visor. The fob operates exhaust brake, all aux lighting and aux fuel tank pump & valve.
Old 06-22-2014 | 04:38 PM
FordTrax's Avatar
remote - now that is new to me. I did not even know that was an option. What brand exhaust brake are you running?
Old 06-23-2014 | 09:51 PM
Festus's Avatar
I'm running a Pacbrake PRXB. A remote switch is not an an option from them. I used 1 channel from a DEI 6 channel remote switch in place of the supplied from Pacbrake to trip the exhaust brake on and off. A 4 button key fob runs all 6 channels on the remote switch under the hood - no wires for anything non-OEM are run into the cab, and no drilling holes for switch placement or any thing of that nature.
Old 09-22-2016 | 05:54 PM
thenrie's Avatar
I know this is an old thread, but I am trying to decide which switch for my truck when I order my BD exhaust brake kit. Saw this post and was interested.
Festus, if you see this, would you mind posting a thread about how you set up your remote system for aux lights, exhaust brake, etc? Sounds like a very useful and convenient setup.
Busboy
21
06-10-2011 11:39 AM
hoot
03-14-2011 04:43 AM
deere nut
10-06-2005 07:44 PM
rharveysr
01-27-2004 07:16 AM
brassbuldog
08-18-2003 09:32 PM
Quick Reply: Exhaust Brake Switch - What Switch and Where
