engine shudders under power
I just had a set of remaned 50hp injectors installed, now the truck shudders under power. It idles fine, starts up with no problem. No codes. ???
2006 megacab 2wd dually, 4 speed auto, AFE stage 2 cold air intake, AFE intake plenum, 50hp remaned Bosch sticks, Magnaflow 5" turbo back exhaust, H and S xrt pro programmer
Cummins Guru
Ohm check the wiring harness and injectors, check the plug in make sure there are no spread terminals. All the injector nut torque to 8 inch lbs.
if you had no problems before its injectors.$40 kill test will let you know quick.I cant say it enough dont buy common rail injectors but from exergy or schied or you will have trouble and save in the long run.yep they cost more
Thanks it was the #5 injector. All of the other injectors ohmed out at .5 M ohms and the #5 ohmed out at .00 M ohms
blow'n'smoke
11-13-2013 12:14 AM
blackdiesel
01-10-2006 02:40 PM
