Engine rattle signs of mechanical failure
yes sir, I tore down the engine today only to find lots of metal shavings and two broken damper bolts. Other than that things looked pretty good.
Valve seats look good, head gasket was perfect, push rods ace.
The problem should be found tomorrow, I will pull the remainder drop the pan and see.
Signs of the problem loud rattle after 1600 rpm, rattle continued after throttle was released.
Second subject
I installed a Fluid Damper 2000miles ago. I installed the damper my way and DID not follow Justin's advice nor Fluid Dampers advice. When using a damper under high horsepower applications a second dowel pin should be installed. I neglected to do this and guess what two bolts are sheered off along with the dowel pin.
Since my bottom end will come apart I will have this repaired.
So after I find out what's up, I will be in the market for more parts. My guess is crank bearings, I hope the crank is OK.
I'm dirty and blue
Don my injectors are on route for an inspection...via UPS over night
Second subject
I'm dirty and blue
I fear brass There are only a few places they put it and none are good. I would say with knocking and brass it would be the wrist pin/piston bushings. This is only a partially educated guess so take it for whats it worth. At least you have the head off and it would be easy to pop the slugs up and check them out, except for the pan in the road. Good luck!
Second subject
I'm dirty and blue
Second subject
I'm dirty and blue
What install procedure did you use? Please explain.
My quick/short opinion of all this is that the damper bolts were not torqued properly to begin with. Even with 2 locating pins installed, an undertorqued damper will still fail and shear bolts and pins.
Further the instances of the bolts shearing with the fluidampr application came out of "one" diesel shop that was probably trying to follow Fluidampr's directions on installation. The directions are correct however it is hard for most to work out a 60 degree final angle when turning a bolt that is not visible to them.
On another note, I do not rule out bolt integrity as a possible cause.
It would be nice if they included new bolts with the new damper. Heck they are over 4 bills new.
Rob did you replace your bolts when you put on the dampner? I know you are suppose to replace anything that gets stretched by rule of thumb. I ran down to the dodge dealer (in a hurry for what I don't know) were the charged me $18 for 4 bolts (ouch) I hope its nothing major but it don't sound good.
Ron
Ron
