Engine oil bypass oil return..
Hey all the return cap is leaking on my amsoil bypass..instead of getting a new one I was thinking about drilling and tap the valve cover. Any thoughts, pro, con? Thanks!
Like this...
Like this...
The oil returns awfully slow from the head on the 5.9's.
I would be afraid of too much oil staying up top, possibly causing excess oil to leak past the guides and seals.
Here's the best way to do it:
http://stuff.is-a-geek.net/PhotoAlbu...ics/CRD_04.JPG
Why clutter up the engine bay?
What is that through the pan? I am sorry I am on my phone so the resolution is not that good. My only concern is the metal savings in the pan, how do you protect against it?
I don't think it's that slow.... consider how fast you pour 11 qts of oil into it when you do a change.
You could use one of the knockouts into the oil pan since you don't have twin turbos.
Personally I wouldn't worry about putting it in at the valve cover. Honestly I believe most peoples return is through the oil cap anyway.
I think I am going to go with the valve cover...so next dumb follow up question any specific location that would be better than any others? Should I just drill into the filler neck? Thanks folks!
tacohat
08-07-2013 06:23 PM
pybyr
07-30-2006 09:33 AM
Scrambler250
11-05-2004 10:02 PM
